AVS › AVS Forum › Video Components › Home Theater Computers › Media Browser 3 is coming!!
Media Browser 3 is coming!! - Page 38
post #1111 of 1323
The Live TV screenshot in the article looks very promising. I'm wondering if it will be incorporated on the server side or the client side. That would enable me to do away with WMC completely as a front end once all is said and done.
Gear mentioned in this thread:
post #1112 of 1323
Originally Posted by lukemb View Post
Some new live tv shots:
http://thedigitallifestyle.com/w/index.php/2014/01/15/live-tv-coming-media-browser-platform/
It's coming very soon. Also, join our linux and OS X test groups:
http://mediabrowser3.com/community/index.php?/topic/3634-mono-server-linux-os-x/
Hi Luke,
Does the Linux test group mean a "native" server app for Synology nas products is being developed? You mentioned something about "mono" before but I dont really know what "mono" means in this case.
Keep up the awesome work!
post #1113 of 1323
Originally Posted by scott750 View Post
Are you talking about the mb server we interface? Like in the metadata manager? I don't see anything that says played.
Go to "browse library" and under media folders pick the section that has the movies you want to mark as watched. There should be a check mark next to the thumbs up and thumbs down icons for each title. If you click a grey check it will turn it red marking that title watched. If the check is red you can click it and turn it grey for unwatched.
post #1114 of 1323
Originally Posted by hifiaudio2 View Post
Hi Luke,
Yes we'll have native apps.
post #1115 of 1323
Guys,
We have a new app release. We're now in the Chrome web store:
https://chrome.google.com/webstore/detail/media-browser-3-status/egofcbleniceaoleohckegkeepennpcn
It's a browser extension that will give you MB Server notifications, and will probably soon be enhanced to add remote control features;.
post #1116 of 1323
Any chance of chromecast? Being able to chromecast from an ipad would be pretty sweet!
Just finished watching Oz in 3d with mbt without a hickup. Great stuff for something that isn't even beta.
post #1117 of 1323
Thank you so much!!!
post #1118 of 1323
So I'm thinking about making the jump to Media Browser 3.
After spending countless hours customizing my current MediaBrowser set up, I'm a little hesitant on going through the same process to get it to look and feel the same.
Is it possible to go through this upgrade in the background so I can continue to use my current set up until the finished product is complete?
post #1119 of 1323
If memory serves correct the MB3 server installation will remove the MB2 installation.
So you won't be able to without installing and configuring on a different system.
Mr Zoid
Sent from my SCH-I545 using Tapatalk
post #1120 of 1323
Will i need to buy a new copy of all my plugins?
post #1121 of 1323
That's a bit of apples to oranges because the plugins are different and built new from the ground up. You could install the server by itself, play with the web client and maybe a mobile client or two all without affecting MB2. It's only when you install Media Browser classic that you will not be able to have that on the same machine as MB2.
post #1122 of 1323
can i just copy over my cache, Imagecache, IBN and startup folders over to the new MediaBroswer-Classic folder?
post #1123 of 1323
No, if you did that they would not be utilized. IBN belongs with the server app.
post #1124 of 1323
Interesting... Would you be able to point me in the direction of a guide I could use to set it up?
post #1125 of 1323
I'm already getting a bit frustrated.
I've downloaded and installed the MB Server onto my HTPC.
After the initial configuration of the server I downloaded and installed MBC. I was prepared to completely reconfigure my setup, however I was not prepared to run into the amount of problems that I have thus far.
I can't seem run MBC for more than a few minutes before I get "Media Browser 3 is not responding" error.
When it does work, it is miserably slow.
I've run MB2 on my HTPC for the past 2 years or so with no problem.
Have the system requirements changed?
Does running the server on the same computer as MBC cause issues?
post #1126 of 1323
System requirements have not changed, and running it on the same machine is perfectly fine. We have quite a few users doing that. Can you post about this in our forums? We have quite a few people who can give you help:
http://mediabrowser3.com/community/index.php?/forum/22-general-help/
If I had to guess it is probably leftover Mb2 components causing a problem. In MB2 some themes actually placed assemblies into windows\ehome. I believe MBC tries to remove those files but it not always successful. That would be my guess as a possible problem.
post #1127 of 1323
I had to completely remove mb2 to get mb3 to run properly.
post #1128 of 1323
Does the new install of MBC not remove MB2? What's the best process to completely remove MB2?
I thought it may be theme related so I removed chocolate and tried again. Same problem. Within 60 seconds of opening MBC it crashes.
post #1129 of 1323
How were you navigating? Keyboard? Remote?
Were you doing anything when it crashed, like scrolling?
post #1130 of 1323
I have noticed MB-C crashes a lot when scrolling on every system I have it installed on.
post #1131 of 1323
Scrolling with the keyboard frequently crashes MBC in my experience. But not so much with the remote control. I think the hold-down repeat rate is lower with the remote control than with the keyboard.
post #1132 of 1323
Its probably been discussed but does Media Browser 3 support 3D playback?
post #1133 of 1323
Interesting, I use a universal paired with flirc. The flirc firmware registers as an HID keyboard, and it uses the repeat rate that you specify for the keyboard within windows. I've never tried to find this option for the real ehome remotes, I'm sure it's in the same place. If it's just the rate then it's an easy tweak
post #1134 of 1323
I have no idea if it is the repeat rate, that was just speculation on my part. But definitely keyboard scrolling crashes MBC frequently and my remote scrolling does not.
post #1135 of 1323
Guys I'm really pleased with the growth of our project and I think you'll enjoy being a part of it if you'd like, whether you're a user or potential developer. Just look at the flurry of activity over the past three days:
http://mediabrowser3.com/community/index.php?/blog/1-media-browser-developers-blog/
- Server release
- New app in Chrome store
- New XBMB3C release
- Preview of upcoming iOS app udpate
post #1136 of 1323
I am trying to setup anime collection. I installed the Anime plugin but I do not see the option to use it when editing my metadata. Also only certain anime shows that I have give me the option to enter information on the 'External ID' field so I can manually input the information. I do not mind entering the data manually but trying to determine why it is not picking up some of my files.
For example Claymore, Samurai 7, Redline, Naruto, Hajime No Ippo and a couple of others. These all have 'Season' folders within each show.
post #1137 of 1323
- Server release
Very nice, Luke!
post #1138 of 1323
post #1139 of 1323
A new theme has been released for Media Browser Classic, Square, from Soultaker, the developer of the popular Neo and Pearl themes.
post #1140 of 1323
You guys are on a roll! I see you have the team well at work and your progress is impressive. Now what's next ?biggrin.gif
