AVS › AVS Forum › Classifieds › Audio Gear › FS; Klipsch RB 3 Bookshelf Speakers.
For Sale: FS; Klipsch RB 3 Bookshelf Speakers.
post #1 of 1
This Classified is Closed
For Sale:
Will Ship To: 48 CONUS
These are in like new condition.No scratches dents etc.Grills are intact.Used as rear surrounds so these have never been pushed hard.These are the original Reference RB 3s.
FREQUENCY RESPONSE: 52Hz-20kHz±3dB
SENSITIVITY: 94dB @ 1watt/1meter
POWER HANDLING: 100 watts maximum continuous (400 watts peak)
NOMINAL IMPEDANCE: 8 ohms
ENCLOSURE TYPE: Bass reflex via rear-mounted port
DRIVE COMPONENTS: Two-way system using one 1" (2.54cm) magnetically shielded, titanium dome compression driver tweeter with a 5" (12.7cm) square 90°x60° Tractrix® Horn and one 6.5" (16.5cm) magnetically shielded, aluminum cone woofer
TWEETER: K-121-KB 1" (2.54cm) Titanium dome compression driver
HIGH FREQUENCY HORN: 5" square 90°x60° Tractrix® Horn
HIGH FREQUENCY CROSSOVER: 2600Hz
WOOFER: K-1081-SB 6.5" (16.51cm) Cerametallic® cone / cast polymer frame
DIMENSIONS (H x W x D): 15" (38.6cm) x 7.68" (19.7cm) x 9" (23.04cm)
WEIGHT: 15 lbs. (6.8kg)
ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
FINISH Black wood veneer
Asking $325 Shipped obo.
Paypal accepted
View All More from This Seller
No Image
For Sale: $700 (USD)
No Image
For Sale: $1 (USD)
  Back to Forum: Audio Gear
