Ok guys, I got a P55ST50 a November 2012 Build (-2). I get slight buzzing sounds that fluctuate depending on the brightness of a scene. I can hear it with low volume up to level 8, at bright scenes from about 8 feet away. This is more apparent when I watch bright scenes in blu-ray that are quiet like in (Planet Earth).
Now I've read all the discussions about buzzing and such, most people don't have much luck exchanging or getting repairs (tightening screws, and board replacement). I've also ran out of Amazon's 30 day return window. So I'm going rogue, and I think we need to figure out a way to silence those 2 pairs of coils, that seems to be the main culprit.
1.http://www.avsforum.com/t/1444504/needhelp-plasma-buzzing-panasonic-st50-when-is-it-not-acceptabel/60#post_22714768
2.http://www.avsforum.com/t/1444504/needhelp-plasma-buzzing-panasonic-st50-when-is-it-not-acceptabel/90#post_22732117
I believe that by properly opening up the back panel, then applying the proper epoxy/glue will silence those pairs of coils.
I've built a lot of pcs and I have experience in repairing computer hardware. So I already know the risks involved.
Can anyone recommend any electronic glue to use on the 4 coils mentioned by caice 7134 in that second link above?
Good luck, and if it works, come back and share; you'll be an insta-hero
