My Setup:
Refinishing a basement. Have the frame up, no drywall yet. I'm looking to do a 5.1 system in the HT part of my basement. The theater will be 15' wide, 22' long and the ceilings will be 7'6". The room is mostly closed of, but not completely. If you are sitting looking at the screen in the front right there is a hallway up to the stairs with a door at the top. the last 8 feet on the back right is open to another room 8' x 20' orientated perpendicular to my HT.
What I need:
5.1 system that will be powered by my Denon 2113. My budget is $1,200 for the speakers and sub. Use will be 50%sports and tv, 30% movies, 20%music.
What I need from you:
Can you look at the following shortlist of setups I have come up with and comment if they are compatible with my reciever and room layout.
I have listened to some, but not all, of these systems and plan to do so before choosing. Can you comment if they are all in the same class of speakers. I am not neccessarily looking for preference of brand or dome vs ribbon vs horn, but just if they are of similar build quality and audio fidelity. I will develop my preference by listening to them.
Finally, can you just let me know if you think any of my centers are not a good match for my towers? I tried to match brands and lines, but am ignorant to timbre matching.
Short List
Refurbished Boston Acoustics.
(2) A360 towers
(1) A225 center
(2)A25 surrounds
(1) A250 powered sub
Cost:$900. Only concern is white towers and black everything else. If better than the rest I will do it. If all else is equal, might pick a matching set.
BIC Package
(2) PL67 towers
(1) PL26 center
(2) PL66 surrounds
(1) PL-200 powered sub
Cost $1175. Haven't listened to horn tweeters ever, so I would have to hear before buying.
Pioneers
(2) FS22 towers
(1) CS22 center
(2) BS22 surrounds
(1) HSU STF-1 powered sub
Cost $800. Seem like a great value. Quality on par with the others?
Polk
(2) Tsi300 towers
(1) CS10 center
(2) TSi200 surrounds
Cost $1150. Didnt like the sub that came with the package, so would have to buy piece by peice. Worth stepping up to the TSi400 and CS20 for another $150.
Thanks in advance with any advise you can lend.
What I need:
Short List
(2) A360 towers
(1) A225 center
(2)A25 surrounds
BIC Package
(2) PL67 towers
(1) PL26 center
(2) PL66 surrounds
Pioneers
(2) FS22 towers
(1) CS22 center
(2) BS22 surrounds
Polk
(2) Tsi300 towers
(1) CS10 center
