AVS › AVS Forum › Video Components › Home Theater Computers › Need Help.....
Need Help.....
post #1 of 12
So I'm going to attempt to build my parents a htpc. I've built my own computers so that isn't the problem. The problem I have is that I only have a budget of around $400. Can you guys give me any idea of some cheap builds?
post #2 of 12
Any input at all will be appreciated. Also what processors would I need to play 3D dvd and blu rays?
post #3 of 12
http://assassinhtpcblog.com/
The hardware guides are free and mostly up to date. The software guides are behind a $25 paywall but make life much easier. Some of the software guides are free though.
post #4 of 12
It would be helpful if we knew more about specifically what you intend to do. Such as:
Do you need on board video?
Do you need HDMI?
Do you need some way to pass audio (such as optical out)?
What kind of storage space are you looking for?
Do you have a preferred form factor (i.e... space constraints)?
Are you starting totally from zero, or do you intend to use some spare parts in the build?
Do you already have some idea what kind of front end you'd like to use?
Are you using it for DVR/cable, music, DVD playback? All of the above?
What are your parents comfortable with as far as technology goes?
post #5 of 12
Do you need HDMI?
On board video: Preferably
HDMI: Yes
Audio: no
Storage space: inside of a tv stand
Preferred form factor: Micro ATX
Starting completely from scratch
No idea for front end
Needs to play dvd and blu rays in 3D and play movies stored on the Hard drive
There pretty comfortable with technology and if anything I can teach them.
post #6 of 12
I searched avsforum for information related to 3D and what capabilities a system would need to have to do it well. The thread I came up with is http://www.avsforum.com/t/1240499/faq-for-the-3d-htpc. Please read through this and get some idea what you'll need. I think 3D will be the toughest of your design criteria to meet, and given that I know very little about 3D, I'll defer to the forum membership and the link above for that.
I predict, however, that your criteria cannot be met within your stated budget.
post #7 of 12
Ok thank you for your input. One more question. Right now we are using a Comcast supplied router for wifi and it's horrible. I've heard we can put that router into bridge mode and use our own router. Which routers would you guys suggest are the best for a small to medium sized house?
post #8 of 12
If you didn't need 3D, you could do something for $250 -$300 easily... Atom/Ion or AMD E-series board with processor, RAM, HDD, Case, Remote, Tuner, WIN7.
post #9 of 12
The cheapest way to 3d is an AMD a-6,a-8 or a-10. You should be able to do this for $300.
post #10 of 12
So instead of Starting a new thread I'll ask here. Would this be a good router and adapter setup?
Adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16833320112&cm_mmc=SNC-YouTube-_-NETV-_-4qQERuwmx4A-_-33-320-112
Router: http://www.newegg.com/Product/Product.aspx?Item=N82E16833320115
Right now I have a Comcast modem that acts as the router also but I have been told I can put it into bridge mode and use my own router.
Edited by Butters361 - 2/12/13 at 8:03am
post #11 of 12
bump..
post #12 of 12
Asrock Micro ATX motherboard (77 variant) $69
LGA1155 Socket Ivy or Sandy Bridge CPU like this: ($35-$50)
http://www.superbiiz.com/detail.php?name=G1610BOX
Coupon Code : HeartBeat. (10% off)
Case: Silverstone MILO 03 $59
8GB DDR3 1600mhz ($35)
120/128GB SSD ($80-$90 for a good one. Cheaper for a crappy one.)
PSU = $20-40. Seasonic variants are the best choice but I've built plenty of systems like this without them to save $$. Corsair and Coolermaster often go on sale for the 400watt variety around $20.
If you want local storage get a Seagate 3TB 7200.14 HDD. $120.
Done.
