AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Help – Building Dedicated Home Theater Room
post #1 of 5
Originally Posted by jstolzen View Post
I'd HIGHLY recommend hiring one of the experienced HT design people here on AVS FROM THE GET GO.
Who would that be? I've seen DE and BPape mentioned on here do they have websites? I'm developing my basement and need some help with the design before I start building. My room will be about 13.7' x 17.75'. How much should I except to pay for this service?
Edited by Helheim - 2/1/13 at 9:42am
post #2 of 5
To the best of my knowledge the Erskine group still offers the basic design service via Shawn Byrne (SierraMikeBravo) for $500. IMHO the best $500 spent by someone just starting to think about their first dedicated theater. Now if you need framing designs, wiring diagrams, detailed construction notes, soundproofing instructions and acoustical treatment prescriptions expect to pay more.
http://www.avsforum.com/t/586330/isf-calibrators-where-are-you-located-please-post-here/1080_40#post_15713517
post #3 of 5
Is the AV Science The Home Theater eBook worth buying? When you go to that page to buy the eBook there are a couple other services you can get too:
Home Theater Consultation: $249
Professional Theater Layout: $497
How do they compare to SierraMikeBravo?
post #4 of 5
The book is worth buying it features some of my work!
Warren Peterson is knowledgeable and I'm sure the basic theater layout service is worth the money. But the Erskine group has a deeper technical knowledge base and considerably more competed projects under their belt. As I mentioned earlier if you need details beyond the basic the Erskine Group can provide those plans as well.
Edited by BIGmouthinDC - 2/2/13 at 8:19am
post #5 of 5
DE is at www.erskine-group.com
Erskine Group can also be found on Facebook.
You can contact Erskine Group using the following email addresses (erskine-group.com follows the name):
info@
ShawnByrne@ (SierraMikeBravo)
WPeterson@
