Budget: Under $200
Size requirements: 10" or 12"
Room dimensions: 350 sq.ft. with dimensions shown below
Primary uses: Home Theater room
Listening habits: 90% movies and sports
Appearance requirements: None
Timeframe: None
I have two Klipsch Icon VF-36 floor standing speakers with Klipsch VC-25 center and VS-14 surrounds.
I am trying to decide between Dayton Audio Sub-1000 or 1200 (leaning more towards one of these due to price, or a BIC F12 or Polk PSW505 if there is much difference to the Dayton. I know the Bic and Polk are relatively the same with varying opinions, but I would probably lean to the F12 if I was to spend the extra money. I would really like a Klipsch RW-12D but the budget doesn't allow for it now.
I am curious if the Sub-1000 would be much different than the Sub-1200 in my room, and if later adding on another Sub-1000 would fill in the difference.
Thanks for the help.
Timeframe: None
