I am a total novice with a need to put up an FM Antenna for a new Marantz SR4023.
If the moderator thinks this belongs elsewhere then please tell me where you will be putting it.
Problem is that my Marantz SR4023 needs an antenna. So, I was looking around in the attic and see a previous owner had installed a
...........................Starfire DA4300V Distribution Amplifier Splitter 300 OHM Channels 2-13; FM 117 V, 60 Hz 0.04 AMP
I have not the slightest idea what that is and if it will help me. Google doesn't know either. Can I just get a long dipole antenna and tack that to the rafters? Will that help?
Note: the FM antenna wire that came with the receiver has a 'male' plug that goes into a 'female' socket on the back of the receiver; so how do I attach a dipole antenna wire to this wired unit? see...
http://m.us.marantz.com/DocumentMaster/US/SR4023_U_EN.pdf
Reminder, I am a total novice, so, please translate any advice into language for the layman.
Thank you.
Thank you.
