AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Need to build a 120" BOC screen
post #1 of 4
The last BOC screen I built was in 2004. I'm getting a new projector with short throw and now I'm in between moving the projector closer or building a bigger screen. If sourcing BOC wider than 54" is going to be a task then I might just trying and figure out how to move the projector closer.
It's been 8 years so maybe there are other sources of wide BOC that has been discovered?
post #2 of 4
Here you go.
http://www.rosebrand.com/product34/Blackout-Lining-FR.aspx?tid=7
No where is 110" wide (Tall) BOC less expensive. Some re-badge the same material and call it "Screen Material" and sell it for 2x the cost listed. Don't be fooled.
At 110" wide (Tall), you can go just about as big as you could desire.
post #3 of 4
Thank you! I also found after some more digging, the website carlofet.com. Rosebrand was my source years ago so I'll revisit them also.
post #4 of 4
The price difference is currrrrazy big. No real choice IMO.
  Back to Forum: DIY Screen Section
