Originally Posted by
reno55
We are currently looking for a tv for our family room. The couches are about 8ft 3 inches or so away from the wall where we will mount tv. Viewing angle is couches on the side, so not looking straight on at tv. .... The question is 42 big enough or should we go to 46/47?......
If you primarily view HD material, would opt for a 50 - 55" panel at that distance. A 60" would look fine with blu-rays - marginal with less-than-HD programming (that is, almost Anything Else...).
For SD programming, including SD DVDs, would stick with a 50". If you view Mixed Programming, but expect a transition to more HD material, 55" makes a wonderful "compromise" size.
?? as to Windows depends upon their location in relationship to the panel, whether you have any covering (drapes / curtains / blinds....) for them, the direction they face, and how much viewing you do at the "difficult" times of day (for your location).
Note that few panels have a Matte Finish now (visit Cnet: they maintain a running list of matte finish sets), and thus Reflections can be a problem for most LCDs as well as Plasma panels.
Plasma still provides much better off-angle viewing than LCD sets - but the latter do vary, with some being distinctly better than others (Consumer Reports rates panels for Viewing Angle, and would be worth looking at).
Good luck with your research!
