I'm looking to build a DIY sub, as I've seen that they can outperform much more expensive ones for a lower cost, but I have no access to a table saw or the ability to store huge amounts of MDF. Is there some kind of a DIY kit that I can just paint the box and plug in the amp and screw in the driver? Thanks.
2/5/13
Taking the information gained from the very helpful people here, especially ack_bk and Jay1, I've decided to go for a Dayton 390HF 15" driver in a ported box. I'll be making it around 6.5 ft 3 but I'm still messing with the setting in WinISD.
2/6/13
Dayton RSS390HF
CSS PA500 linked above
~6.5 cu ft. I'm going to aim for this but not complain too much if it ends up a little less due to bracing, ports, etc.
2, 23" ports
Tuning to 20 Hz which gives me this SPL
2/7/13
Going to go for 8 cu ft, because the low end extension seems to be better than the 6.5 cu ft, but I'm sure I'll be blown away regardless.
Costs:
Open cell foam for stuffing: $12.85 + shipping
Dayton RSS390HF: $172.69
CSS PA-500: $239
4" tuning kit x2: $27.80
MDF: $35
Edited by edlittle - 2/7/13 at 12:28pm
2/5/13
2/6/13
Dayton RSS390HF
2, 23" ports
2/7/13
Costs:
CSS PA-500: $239
MDF: $35
