Originally Posted by N8DOGG
They should not have blown, they should have been able to handle way more power. I don't know why they fried but both subs cooked at the same time on "scary christmas" dub step song I play to make sure they have no problems before I ship them away. They were SI 18's in 3 CF boxes. They might have been getting 650 watts, if that. It just surprised me I guess. I've been putting quadruple power to subs for 10 years now and never had one smoke a coil. I've had damage from over excursion but never thermally. 2 seperate dayton 1000 plates amps. Crazy stuff. I can get a VC made no problem and I've got a few re-cone kits laying around that should be ok.
Originally Posted by Bill Fitzmaurice
Agreed, and note that I stated that this is a persistent myth that won't go away, partly because parties that should know better continue to spread it.
Were you monitoring the power? If not you can't know for sure that overpowering didn't occur, and if you cooked drivers then the only logical conclusion is that it did. I've blown exactly one driver in the last 40 years, an EVM15B that I was testing. I was using a 50 watt amp and an errant transient pulse took out the 400w rated voice coil in the blink of an eye.
WOW crispy coils on ~600W playing program material.... I agree something doesnt sound right.
I wonder if the amp has anything to do with it? Do all amps behave the same when "clipping?" I think those amps have a variation of Bob Carver's power supply design at work. Its kinda like a smps i believe and doesnt behave proper when sent sine waves at full tilt, which is why they rate them 1/3 duty cycle and no RMS ratings.
That's the only reason I'm even checking out this thread. I have no clue what you guys are talking about but I hope I will learn something through osmosis.
