$100 (USD)
send a PM to take the next step.For Sale:
Samsung 26", 1080i CRT TV
Will Ship To: Nowhere -- local only
Presented for sale is a Samsung TXP-2675WH, a 26" widescreen 1080i CRT TV. This TV has an ATSC tuner built in. It was purchased new from Tweeter in 2005, and saw light use in our basement family room. I do not have the original box, so this would have to be local pickup only in the Chicago area. See specifications listed below.
Thanks for looking.
Mark
Specifications
Screen size: 26 inches
TV type: CRT with fine-pitch, dark-tint DynaFlat picture tube
HDTV capable: Yes
Aspect ratio: 16:9
Aspect-ratio control: Normal and zoom (screen-filling) modes
Speaker wattage per channel: 10
Number of speakers: 2 (2-way each)
Comb filter: 8-bit, 20 MHz, 3D Y/C
Electron gun: Dynamic, multiple-focus
Horizontal resolution: 800 lines (maximum)
Invar shadow mask: Yes
Scan velocity modulation: Yes
3:2 pulldown reversal: Yes
Noise reduction: Yes
Signal type: NTSC, ATSC (480p/720p/1080i)
Black-level expansion: Yes
White peak limiter: Yes
Auto channel setup: Yes
Auto clock set: Yes (reads XDS broadcast data)
Channel labeling: Yes
Input labeling: Yes
Channel coverage: VHF 2-13, UHF 14-69, CATV 1-125 (up to 181 pre-selected channels)
Closed captioning: Yes (CaptionVision)
Picture modes: Standard/Dynamic/Movie/Custom (with user-adjustable brightness, contrast, sharpness, color, and tint)
Picture enhancements: Dynamic Multiple Focus Electron Gun, Pro Picture 3-Stage Video Correction; Vertical Compression (maintains vertical resolution and quality during anamorphic widescreen sources such as DVD), Digital Chassis
Screen capture picture freezing: Yes
Auto Kine Aging Bias: Yes (automatically regulates the white balance to maintain consistent, optimal performance even after many years of use)
Non-volatile memory: Yes (preserves settings in the event of a power outage)
Electronic program guide: Yes (Digital Program Guide)
Tilt correction: Yes
Last-channel recall: Yes
Multilingual menu: Yes (English, Spanish, French)
Translucent OSD: Yes
Parental control: Yes (V-Chip)
Picture-in-picture (PIP): No
Remote control: Yes (universal)
SAP: Yes
Sleep timer: Yes
On timer: Yes
Remote Surf timer: Yes (returns TV to original channel after a fixed time so other channels can be browsed during commercial breaks)
Audio tone controls: Modes for:Music, Speech (focuses on dialog and reduces background sounds), and Custom (5-band graphic equalizer allows detailed sound adjustments)
Sound enhancement modes: Standard, Movie, Music, Speech, and Custom
Surround sound: Yes (simulated)
VGA/SVGA input: No
Audio outputs: 1 stereo analog (left/right RCA, fixed-level)
Audio inputs: 3 stereo analog (left/right)
Video outputs: 1 (composite-video)
Video inputs: 5
Headphone jack: Yes (.125-inch, side panel)
Digital-video input: 1 (DVI-HDTV)
Component video: 2 (both auto-sensing 480p/480i/720p/1080i)
Composite video: 4
S-video: 2
RF: 2
Color temperature control: Yes
Front AV jacks: No
Side AV jacks: Yes
Sound leveler system: Yes
Antenna: CATV/VHF/UHF 75-ohm, F-type
Power supply: 120W AC, 60Hz
Power consumption: 190 watts (1.9 watts standby)
Energy Star compliant: Yes
UPC: 036725226401
Width: 31.9 inches
Height: 21.1 inches
Depth: 20.3 inches
Weight: 88.6 pounds
Shipping dimensions: 36.1 x 26.5 x 24.5 inches (W x H x D)
Shipping weight: 101.4 pounds
In the box: TV, remote control, remote batteries, user's manual
Thanks for looking.
Mark
Specifications
HDTV capable: Yes
Aspect ratio: 16:9
Input labeling: Yes
SAP: Yes
Sleep timer: Yes
On timer: Yes
VGA/SVGA input: No
Video inputs: 5
Composite video: 4
S-video: 2
RF: 2
Front AV jacks: No
Side AV jacks: Yes
UPC: 036725226401
Width: 31.9 inches
Height: 21.1 inches
Depth: 20.3 inches
Weight: 88.6 pounds
