Originally Posted by
BoogereaterÂ
how exactly are you doing this via HAI? You may want to issue a direct command to lutron via the HAI program vs. issuing a phantom button/scene via lutron.
If you are issuing a command to do something you need to issue a command to stop doing it as well...I know this seems trivial but it's a mistake that a lot o folks make...even me on occasion.
HI thanks for the reply.
In radio ra essentials I created phantom button #9 This is programmed as 'security mode" type
this button is programmed to flash certain lights
In HAI pc access I created an automation as follows
WHEN ANY ALARM
THEN Phantom Button 9
So now when my alarm goes off this phantom button gets pressed but then never gets shut off and I am locked out of all local control of any light switches until I reset the radio ra processor
Is this not correct? How would I issue a direct command to lutron to turn off phantom #9
Since If I can do that then all of the lights will exit security mode and go back to the previous state they were in.
THanks!
Edited by cmcjo - 2/2/13 at 6:40am
