I've been thinking how to write a thread to best discuss this topic for a long time now.
After considering it at length, I decided to start with the general topic rather than as a problem of my specific equipment, and how to set it up. We may eventually degenerate into an equipment specific discussion, but I am electing not to begin that way. If it's absolutely necessary, I'll post new thread topics specific to my equipment in other forums, and provide links to them here.
Generally speaking, you should know that I am addressing myself to those with Surround Sound processors such as DSP based Digital Receivers with DTS, Dolby Digital [aka DD5.1, AC3 and Dolby HD] with TOSlink [optical], Coax, or HDMI capability and combinations of same.
* Owners of THX certified systems will find this thread of particular interest as these are in my stable, and may be discussed.
Overview:
With the advent of the Blu-Ray format and it's winning out over HD-DVD - the issue of Dynamic Range in home theater has come to the foreground. In the past couple years, particularly in the U.S. region, fewer and fewer titles have been issued with Dolby Digital compatible sound tracks as the primary [English in my case] track and indeed - DTS HD Master Audio tracks appear to have become the defacto standard.
Moreover - while alternate language sound tracks are often included in Dolby Digital 5.1 [previously known as AC3] the Gods of Blu-Ray never seem to include one in English. Indeed - if they offer one at all it's usually Dolby Surround, a Matrix 2.0 variation.
I have found that DTS has far too much Dynamic range for my liking. I've grown to really despise it for the vast majority of my listening. In my situation, I cannot count the number of evenings it was necessary to "ride the volume control", compensating by 10db or more from scene to scene to be able to hear spoken dialogue one minute and prevent others in the home from being "rattled from their beds" the next - by gunfire, fog horns and other effects sounds.
I am being quite literal here.
This is a constant annoyance and spoils the mood taking me from enjoyment of many a Blu-Ray title to the point where I have abandoned the visual treat of my HD title in favor of the DVD edition, just to be able to listen to the Dolby Digital 5.1 track and make use of the Dynamic Range reduction features it enables in my Surround Receiver.
In pursuing this goal of HD Video and Dynamic Range Reduction, I have played extensively with various methods of attaining less with DTS sources. These include:
Recently I've been looking into Dynamic Volume functions of Audyssey but been unable to gain access to these in my equipment, even though I see they are supported. [Apparently they're only enabled after a suitable automatic setup sequence]
So, that's the topic.
Thank you in advance for your thoughts and opinions.
Overview:
- Purchase of a Blu-Ray player with Bitstream DTS->Dolby Digital Re-encode capability
- Use of PCM rather than Bitstream settings
- Enabling / Disabling In-Player "Dynamic Range Control" feature
- HDMI vs Optical Sound conveyance
- Selection of a Receiver with Multiple Dolby Digital listening modes [Low and High "Midnight Theater"]
- THX modes and "Loudness" settings
- Am I alone in this frustration?
- Can you tell a story of similar problems?
- Have you found a way around these issues in your system / equipment?
- Has this effected your Disk buying habits? (I always elect the DVD/BluRay combo when available)
- Are there Receivers that offer good Compression with DTS sources?
- Is it my imagination that HDMI and PCM conveyance of DTS is better [less Dynamic Range] than Optical?
- Are there instances where enabling Dynamic Range Control in a disk player in combination with Bitstream re-encode seems to make the problem worse, not better?
- Can you comment on Audyssey in this regard?
and I'd really value your experiences.
