AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Need Firmware for Vizio VA26L or Replacement Turner Box
post #1 of 2
I've a Vizio VA26L that can't decode digital stations on cable... I just get a blue screen, but my channel scan adds the channel because there is a signal. My other Vizio E371VL has no problems decoding the stations. I've done some searching and could not find a firmware update. Does anything know if there is a bootleg firmware update or could suggest a replacement tuner box that would pick up all the analog and ALL the digital stations?
post #2 of 2
What is the source of your Digital Signals: Antenna, cable or satellite? Are you using the ATSC or QAM tuner?
