AVS › AVS Forum › Audio › DIY Speakers and Subs › Reference level+ bass for a ~11,000 cubic foot dedicated home theater space?
Reference level+ bass for a ~11,000 cubic foot dedicated home theater space? - Page 3
post #61 of 66
Originally Posted by Ricci View Post
I wouldn't use the B&C much lower than the 23Hz or so Danley is. IMO it is best kept with corners near 25-35Hz. It doesn't have the displacement of the 5400 or UXL so it would have less headroom in the low bass compared to the GH.
Looks like we were thinking the same thing at the same time - You just type a little faster smile.gif.
post #62 of 66
as far as a tapped horn goes, i'm not sure the build gets much more simple. i've highlighted the panels in red.
A single-fold horn, which is to say one with a single interior partition, is much simpler
post #63 of 66
Ha! For a second there, I thought the handles were windows and the woofer was and 8 footer with half the room dedicated to the fold! eek.gif
post #64 of 66
"A single-fold horn, which is to say one with a single interior partition, is much simpler"
yeah...it would be 12 feet long though, which might present some challenges if it needed to be moved.
jpm... :-)
"It doesn't have the displacement of the 5400 or UXL so it would have less headroom in the low bass..."
that looks right to me. about 5db around the 25hz mark.
steve, that was a nice build over at diyaudio. i never managed to read that thread. sometimes they get a little long. :-)
Edited by LTD02 - 2/11/13 at 4:28pm
post #65 of 66
post #66 of 66
Ya, something like that. biggrin.gif Hopefully, you would not have the same driver destruction when you fire it up! eek.gif
