AVS › AVS Forum › Audio › DIY Speakers and Subs › Can someone help me with wiring?
post #1 of 2
I just started my plunge into DIY audio. I've already made my sub, a TC Sounds Axis 15 with 1000 watt Dayton amp and it's awesome. Now it's time to complete my towers and center. I have 4 Peerless woofers for each enclosure and a Dayton tweeter for each one also. I have 3 pre-assembled Dayton 2 way crossovers at 3000 hz. Can someone please give me advice on hooking all this up. Like step by step directions would be great. Here are links to what I have.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-1078
http://www.parts-express.com/pe/showdetl.cfm?partnumber=275-045
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-144
Any help is greatly appreciated.
post #2 of 2
Sorry to be the bearer of bad news, but you just can't hook up any randow tweeter with a random woofer (or multiples) with an off the shelf xover. Each xover needs to be designed for the drivers it's going to work with.
The other problem I see is the 4 woofs/ch. If you use them WWWWT in a tower, you're going to have to roll off the lower 3 earlier than the many xover to the tweet to aviod combing. Even WWTWW, I'd suggest doing the outer pair for the same reason.
