AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Phono Input reciever
post #1 of 19
Does anyone have any suggestions for a good receiver with a phono input that doesn't break the bank?
Or should I go with one without it, and just a pre-amp ( I think that's what it is called.)
Pretty much I want to play vinyl through my receiver.
post #2 of 19
Could you put that in $$. Breaking the bank for you might be different for someone else.
post #3 of 19
Unless you're considering a higher end AV receiver to begin with, you're probably going to find it much cheaper to buy a seperate phono pre-amp.
post #4 of 19
These days the outboard preamp is the way to go. AVRs with phono preamps are like hen's teeth.
post #5 of 19
Most higher end receiver's have a phono pre-amp built in. Yet another reason to get a better AVR. The small things add up.
post #6 of 19
I would love to stay under $1000
post #7 of 19
Make your AVR choice based on the other features/inputs/outputs you need and if it doesn't have a phono input you can simply buy a phono pre-amp for $50 or so.
post #8 of 19
Is that equal to or better then what would be on a receiver?
post #9 of 19
Likely no real difference either way.
post #10 of 19
Well what is a good pre-amp?
That seems like the best idea most likely, because that could grow with my receivers as I grow my home theater system.
post #11 of 19
First of all what type of TT do you have?? What type of Tonearm?? What cart?? Buying a top end phono is not going to suddenly turn if you have a $399 TT into a high end model. Your working backwards. First look for a quality TT probably in the $800 range followed w/a accurate tracking tonearm preferably at least medium mass in weight. This will give you a larger choice of carts to choose from. At that point choose a phono. Entry level TT's are very nice but limited in what they can do. Basically the TCC TC-750 would be fine at $50 or the NAD PP2 , Rega Phono, Parasound Zphono are a little more but also solid choices.smile.gif
post #12 of 19
This is the one I was going to go with... http://www.uturnaudio.com
I saw a couple things that said it should one of the biggest bang for the buck products.
If that turns out to be a bust I don't want to spend more then $300 on a TT really.
post #13 of 19
In that case the TCC-TC750 would be sufficent add a very reliable Shure97xE cart for around $60 and you should have a nice entry level system. A more expensive phono is really not going to improve your sound dramatically. You must consider the source first. Have fun w/the records. Hope you have some good used record shops near by.smile.gif
post #14 of 19
Actually there is a locally owned shop close to me that prides itself on stuff like vinyls, and harder to find music.
Any recommendations on a cheap lets say sub $150 TT? Just so I can get started.
Edited by Mako0312 - 2/3/13 at 10:42pm
post #15 of 19
USB turntables with line level outputs aren't hard to find in the under $150 prices range. These don't need phono pre-amps, they come it built in.
post #16 of 19
Thinking about buying a older more vintage TT... I see a PL400 on craigslist for $175. Obviously not going to pay that much. What would be a good price?
post #17 of 19
if i were you i wopuld buy used TT, vintage, you choose the brand: Sansui, Technics, Pioneer, etc.
Can get a good used one for under $250
post #18 of 19
If you're going to buy used/vintage, you really need to know what to look for. Belt drive or direct drive? 78rpm capable? Motor still steady & reliable?
Assume at least the stylus will need replacing, and if the cartridge is shot it can be a chore to install & align one.
As far as receivers, look at the Onkyo line for midrange models with phono in:
http://onkyousa.com/model.cfm?m=TX-8050&class=Receiver&p=i
http://onkyousa.com/model.cfm?m=TX-8255&class=Receiver&p=i
Edited by thebard - 2/7/13 at 11:25am
post #19 of 19
I'm going to stay away from vintage then because I have no clue what I'm looking for, and I'm thinking of going to a 7.2 receiver and just use a phono preamp.
Now just time to decide what TT to start out with.
