so i am wiring a PA amp (the 205) to three 8-ohm speakers. 2 of the speakers will be in parallel and the 3rd will be in series off the other speakers. I've found out this will give me a 12 ohm load. on the back of the amp there is a common ground and connections for 4, 8, 16 ohm loads. the manual suggests i connect to the 16 ohm connector with a 12 ohm load.
my question is what is the difference between all the connections. i know the lower the ohms, the more draw there is on the amp. but what i'm getting is why are there different ohm connection options on the amp itself. does the amp output at different levels for each ohm connection?? tia
