AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Running Panasonic Home Theatre Unit through Onkyo A/V Receiver?? Help
post #1 of 4
Hi There
Recently bought an Onkyo tx-nr515 A/V receiver, for the purpose of adding an audio zone to the house.
What i want to know is it possible to run a Panasonic Home theatre unit (sa-btt-370) - pretty much just to run as a Blu-Ray and DVD player, through the Onkyo Amp and then connect to the tv.
The back of the panasonic unit has an HDMI Out port, but I have only been able to get the visual side working.
Any help would be greatly appreciated!
post #2 of 4
go through the setup menu carefully and look for some type of setting regarding embedding audio on the HDMI output. If there isn't a way to reinsert the audio track back onto HDMI, you are out of luck. Searched online for a manual, but didn't have any luck.
post #3 of 4
Here's the manual
http://service.us.panasonic.com/OPERMANPDF/SCBTT770.PDF
Set the HDMI Audio output to on, still no luck. any ideas?
post #4 of 4
wow, thought that would have done it. Next step is call Panasonic and see if it is even possible. Be prepared to wait on hold for quite a while, and probably end up with somebody reading off a script, but you might get lucky.
It isn't encouraging that the manual doesn't make a single reference to connecting the unit to an external surround processor/ AV Receiver......you may be out of luck.
Plan B: move it to another room and buy a Blu Ray player.
