AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › does PS3 play 3D ?
does PS3 play 3D ?
post #1 of 9
if yes where in the menu do i go to set it up ?
post #2 of 9
It does. Not sure where in the menu you go. Try just inserting a 3d movie and seeing what it says. I believe wheni did that I was directed to the setup.
post #3 of 9
It must be connected to a 3D display, then go to the XMB and run the Video Settings. The PS3 will recognize the 3D display, and set up from there.
post #4 of 9
double post
post #5 of 9
the PS3 is connected to an epson 5020 but when i go to video setting i don't see anything to set up 3D
does it have to be playing a 3D bluray?
post #6 of 9
You should not need to have a 3D BluRay or game disc in the PS3 to get it to recognize that it is connected to a 3D TV; once you're on the video settings screen the PS3 should auto-detect the TV's 3D capability and ask you if you want to configure. Is the PS3 connected to the Epson via a high speed HDMI cable?
post #7 of 9
i am using this
http://www.amazon.com/gp/product/B0031TRZX2/ref=oh_details_o01_s00_i00
post #8 of 9
It won't work right off the bat.
Go to display settings on your PS3, Set automatically and your PS3 will detect in your set is 3D enable and it will ask you to set the size of your screen and then you'll be able to watch or play 3d content.
post #9 of 9
re run the audio/video setup -- if you have a receiver in the path, ensure it supports 3-d as well --- otherwise direct connect to the projector and connect your audio using tos-link.
do an auto detect and the ps3 should detect your projector 3d mode.
  Back to Forum: PlayStation Area
