AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › Replacement drive for 50xx unit.
post #1 of 12
Does anyone sell pre-formatted drives ready to install in a 50xx unit?
TIA.
post #2 of 12
post #3 of 12
You can also try Weaknees.com. They sell them, too.
post #4 of 12
The prices on those drives is insane... It took me a while to get it right, but now I just buy a drive and RTV patch it myself, if I can do it most anyone should be able to...
post #5 of 12
yeah, but it's the whole "FIND a suitable drive" that's getting to be impossible.
post #6 of 12
seagate db35.3 drives are best and plentiful--d
post #7 of 12
Seagate db35.5 series are SATA, Replays need old-school PATA drives.
post #8 of 12
and then PATA drives with friendly firmware....
Yes the Seagate DB35.3 ATA/100 drives are great, but I don't think they've been made in quite some time. I think at this stage of the game, it will be difficult to find a NEW drive that will work in a 5000/5500 series RTV. Used / Refurbed.... probably plentiful.
Cheers!
-Doug
post #9 of 12
but what i said is correct---d
post #10 of 12
Cheers!
-Doug
theyre
there all over ebay all sizes new and used and refurb---im using 10 750g i got last year in 8 replays and 2 in my xp comp that hasa 2tb sata hdd as well. there are many 100 120 and 160 hdd added on their home page as soon as i log on---d
post #11 of 12
i also had two replays with WD hdds in them thät i replaced with the 750s that were 80s. they work well i just wanted space to theme rec lots of movies. model wd8000bb-55jkao
post #12 of 12
its a good idea, at first i used weaknees but its well worth and fun to learn to do it yourself. also u still have to net connect to get the latest os and if rtv mothership goes down ull be learning anyway---d
  Back to Forum: ReplayTV & Showstopper PVRs
