I hope this is in the right section. I have a question regarding testing my new CAT5e cable run.
I have a two story house. My Man Cave is upstairs where my projector, surround, HTPC, & PS3 is located. My office is downstairs where the modem, & my router is located. I'm still running an older Linksys WRT54G router, but I've modded it using DD-WRT so it works pretty decent for Wi-Fi, but at the end of the day its still Wireless G vs N and with everything getting higher and higher in quality the streams to my PS3 upstairs are starting to get choppy / lag more than I'd like.
So my solution was to buy some CAT5e cable. I ran about 100-125ft (estimated as I was pulling it off the 1000' reel) terminated the end upstairs to hook in my 5 port HUB and terminated it into a wall plate down in the office. Hooked it up and everything works, but I'm curious to see how I can test the speeds of the cable.
I've used my PS3 to do a speed test using their connection test tool, but its all over the board and I've read that its not even close to reliable. I then hooked it up using my laptop to run speedtest.net and it was better but I was ranging from 8mb/s to 18mb/s whereas my desktop downstairs on a 6' CAT5 cable from the modem was registering 28-31mb/s using speedtest.net.
I have Comcast for my ISP, and am paying for 20MB service. I completely understand that it will fluctuate based on how many other people are on. I guess what I'm looking for is a way to make sure that I'm getting reliable connection speeds over my new long run.
Any suggestions? Thanks in advance!
