AVS › AVS Forum › Audio › Receivers, Amps, and Processors › newbie question- Sony HTIB speakers with Denon 1713
post #1 of 3
Hi,
First of all I must say that I am a noob to AV receivers and speakers. Recently I bought a brand new Denon AVR 1713. I also had a old set of Sony HTIB speakers and they marked 2.7 ohms.
I connected Front L&R and center to Denon 1713. After Audyssey setup, here is the parameters set by 1713.
Speaker config:
Frone: large
Center: Small
Levels:
Front L: -2.0 db
Front R: -2.5 db
Center: -4.5db.
Speakers worked so far however I heard that those speakers might damage my Denon receiver.
Is my setup ok? Will my new receiver survive those HTIB speakers?
Edited by tallmike - 2/3/13 at 1:01pm
post #2 of 3
At average (normal TV level) listening volumes you should be fine, however, if you raise the volume too loud, the AVR will shut down in protection mode before it is harmed.
post #3 of 3
good to know my limits. I will be careful before I upgrade to some "real" speakers.
