It has been a long time since I have done a project, so let's get started, shall we?
This project will involve three of these:
and one of these
and a lot of this
all wrapped up in a nice wrapper.
I started cutting wood today, and using my DowelMax to help line things up once glue-up happens. This will be large, so I will need everything lined up quickly and easily once glued. The wood is 23 3/4" x 48", and I am not cutting them down, just to give you an idea.
I got the dowel holes drilled into the four sides
Then did a test run
It lined up perfectly.
Progress will be slow, but I will keep it updated. Next issue is to cut 19 1/4" holes......the Jasper Jig isn't big enough....darn.
and one of these
and a lot of this
Then did a test run
