Hi all, not been in here for a while.
I have been using a video converter (component in, s-vid out) and Magnavox DVD recorder for a while to record some shows off the cable box to MPEG2 (DVD).
Now we have a couple of WD TV Live media players and I have a networked PC storing/serving up video, I am converting a lot of MPEG2 material to Xvid to save on space. MPEG2 stuff that originally came from DVD looks great after conversion. But the stuff that came from cable > video converter > DVD Recorder > ripped to PC > converted from MPEG2 to Xvid - does not look so hot.
I have a media PC which sits behind the TV stack and is a quad-core Q6700, with 8GB RAM, 1TB drive and Windows 7 x64. At present there is no capture hardware, but I do have a PCI-E firewire card, if that helps.
I was hoping for some advice on what I could buy for the media PC to capture from the cable box (component out) to end up with files of good video quality on the media PC, at which point I can edit on my master PC upstairs (i7-2600k, 16GB, 128GB SSD+2TB spinny drive, Win 7 x64) and convert if needed to the final format (x264?).
I did a search on the forum and the Hauppauge 1212 is mentioned in a few places but that seems to be a few years old now and I was wondering if there is something better or more cost effective. My knowledge of PC hardware and software in general is very high but I've lost touch with current capture hardware options.
Looking to spend maybe up to $200-ish.
TIA!
TIA!
), is it possible with the Colossus [and accompanying software] to capture directly (from 1080i input via component) in resolutions like 720x400? So that I can just remove ads without re-encoding, and retain DivX-type resolution/quality but with much lower filesizes than HD?
