AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › Welp, I moved so I figured its time for a new man cave thread.
post #1 of 6
Equipment is similar to before although a different projector and listed below, Just a new setting so I feel like whoring out some new pics.
Epson 8350
92'' fixed frame screen
Marantz SR5005
Emotiva XPA5
Kef Q900 (2)
Kef Q300 (2)
Kef Q600c
Polk Audio PSW505
Xbox 360
Samsung bluray
Apple TV3
Monoprice HDMI Matrix
Motorola PVR
post #2 of 6
post #3 of 6
Those Q900 setup must sound great and the pics clearly show why Epsons are known as "light-cannons" in rooms with ambient light. I would suggest removing the coffee table though, as it's bound to have some serious sound reflections.
post #4 of 6
Yea the 8350 is awesome for ambient light rooms, and with the auto iris the dark room performance is good as well if you set it to cinema. I love that it can be set to ultra bright mode for watching sports with the lights on.
The 900s sound awesome and part of the reason I went with carpet in the room over wood floors was to deaden the sound, I could remove the coffee table for really critical listening, but its still a living space, I like having a place to put my drink and laptop enough to justify a slight reduction in sound quality for daily use.
post #5 of 6
Hi cream puff, a really awesome setup you have, indeed! Congrats!
1. I surely would not remove the coffee table for obvious reasons as you also mentioned, but would put a table cloth on it to tame those dreaded reflections. Let there be WAF, ask honey to plan it the way she likes it. Design and color makes no acoustical difference. Let's make everybody happy! smile.gif Same goes for the same style small table at the surround speaker on the left side.
2. While talking about surround speakers it would be better to angle them to face each other, in other words the ears of the listeners sitting on the couch. Doing it will immediately improve the immersion of your surround feeling. Worth a try, costs nothing.
3. To do the above two issues best, when done please run Audyssey again.
post #6 of 6
well done. man I really need to get a screen up.
there is just something about it.
cheers
