AVS › AVS Forum › A/V Control & Automation › Remote Control Area › URC Mx780
URC Mx780
post #1 of 3
Does the URC Mx780 suffer from the same "re-learning" bug as the consumer R40? Does it recognize device states? Lastly, would it control my Lutron lighting ( Spacer system plus odd Maestro) and Mitsubishi mini-split? Thanks for the advice- can't find these specifics.
post #2 of 3
The MX-780 is a pro remote and is configured using CCP (Complete Control Program). I am not aware of any re-learing issues with the 780 and have been using one for well over 6 months.
You can use variables to keep track of the state of a device. If possible and your gear has discrete codes for power this may not be necessary. You have to configure all of your activities with the CCP software. All macro's are created by hand in the software by the user.
Is your Lutron IR or RF? If it is IR then yes no issues. If it is RF then only if it is Lutron's URC specific products.
post #3 of 3
Thanks for the input, much appreciated.
  Back to Forum: Remote Control Area
