AVS › AVS Forum › A/V Control & Automation › Home Automation › Good small controller
post #1 of 5
Can anybody recommend a small good and reliable controller? I need to just control a few lights and and a valve. Must be reliable and good quality.
post #2 of 5
Not sure of your exact requirements....but check the CommandFusion Mini Starter Pack.
http://www.commandfusion.com/minipack.html
I can be contacted at aaron (at) commandfusion.com if you have any questions.
post #3 of 5
Also not exactly what all you want. This will allow for future expansion. You would need a dealer for setup.
http://www.control4.com/residential/products/controllers/HC-250/
Edited by Hookedonc4 - 2/24/13 at 10:30am
post #4 of 5
RTI XP series processors will do the trick nicely. The XP3 retails $500 has relay outputs, 3 routable IR, and RS-232 port.
post #5 of 5
I second the RTI XP Vote, controllers are small and should be able to accomplish what you need pretty easliy
  Back to Forum: Home Automation
