Originally Posted by
Eric2000
Hi guys,
I've been following a number of the acoustics threads here for a while, though I haven't been very active on the AVS forums. Mike suggested that I share some of my work on room acoustics with everyone here, so here are my corner bass traps:
I followed a similar construction technique that Mike posted for his corner bass traps, but made mine from pink fluffy R-19 instead and wrapped the fabric around the outside of the threaded rod. Here is the photo journey:
My traps are 24x24x34 inch triangles, are about 3.5 feet tall, and probably weigh less than 10lbs each. Since I need access to one of the corners for a doorway, I made them stackable and moveable. I started by cutting triangles, drilling holes for the threaded rod, and inserting T-Nuts for the sides that stack on one another:
Then I cut 23" squares of insulation, cut them diagonally for triangles, and clipped off the corners so they fit snugly between the threaded rods:
A wire mesh made from separated Cat5 wire goes between each layer to keep the insulation from sagging over time. The numbered arrows indicate the direction of winding the wire to support the insulation. A bead of solder keeps the wire from unwinding. Each layer of insulation is about 5" thick.
Here is the first one all stacked up. You can see the supportive wire mesh wrapped around the threaded rod on each side:
And then with the Kraft paper glued to the front with spray adhesive:
Then, turn the trap upside down to affix the cloth wrapping - a two-pack of curtains from the giant W for $15. Each pack is enough for two traps.
The cloth is stapled to the underside of the top plate to prevent sagging over time:
When the fabric is fully secured to the top panel, turn the trap right side up again and pull the fabric around to the back. Trim off the excess and then just pull it tight and use a desk stapler to hold the fabric together in the back:
The staples produce a few ripples in the sides, but you won't see those once you put it in the corner. The front looks nice and clean:
Here is a closer shot of two of them stacked together:
And finally, the entire back half of the theater. With a few bean bag chairs up front, we can comfortably seat 10-12 people. The colors are a little off from a combination of CFL and flash lighting:
Below are the before and after REW plots. The purple trace is the original measurement with no traps and no EQ. The yellow trace is the difference made by the bass traps alone. The traps took 5dB off of the room-induced peak at 45Hz without sacrificing anything else in the audible range:
This is the original waterfall plot made by REW - no traps, no other corrections - just a mess with room modes at 45Hz and 90Hz:
And here is the waterfall plot after ONLY the traps are put in place. I was surprised by how much of a difference the traps made in the decay:
After several days of tweaking the parametric equalizer with the traps in place and a first order high-pass filter in place, here is my "final" room response curve - flat from 7Hz to 100Hz, plus/minus 3dB :'( The peak at 105Hz won't ever really happen because the preamp crosses the LFE channel at 60Hz.
And the "final" waterfall plot - nice and smooth. If I adjust the waterfall graphing limits in REW, the entire response curve is down by 20dB within the first 100-120ms with the exception of a 2-3dB narrow bump at about 23Hz. I am really pleased with this result:
It sounds great! The EQ and high-pass filter reduce (but don't eliminate) the incidence of amp clipping, but still provide enough punch to cause visitors to literally jump up from the couch :P
All of my other projects are on my web page, which I think is linked in my signature.
Eric
