AVS › AVS Forum › A/V Control & Automation › Home Automation › In Crestron controlling from 3 iPad
post #1 of 2
Hi,
I am having a processor & programmed it, I have made a GUI & installed in 3 iPads. If from 1 iPad I am changing the subpage the same thing is happening in other iPad also. I have give a crosspoint in simple window program also & seperate interlock for all three iPads, but same thing is happening. Your answer will be appreciated. Thanks
post #2 of 2
Are the three iPads connecting to the same touchpanel symbol? If you want hem to operate independently you'll need to define additional Crestron Mobile symbols and the accompanying programming. They'll also need to operate on unique port numbers (default of 41790, etc).
  Back to Forum: Home Automation
