Hi all this is my first post. I bought a new tv, its a 55" Lg LM5850. I'd like to use a different set of speakers because the built in speakers really suck! The tvs only audio output is toslink optical and there is no 3.5mm headphone jack. I have a set of nice Logitech pc speakers and I'd like to use these with the tv but there is no way to control the volume from the tv remote.
I can't have a receiver because not only does my budget not allow for it asI'm looking to spend under $150 but also my entertainment unit doesnt really have room for a bulky receiver. This is my entertainment unit http://www.ikea.com/ca/en/catalog/products/30218111/
My tv fits perfectly in this unit but the two shelves below the tv space for added electronics are only about 4" in height, probably good for a bluray or game console but not a receiver
I was looking at the Logitech z5500 which are great and have optical input but they are way way over my budget, even for a used set on kijiji or craigs.
So my question is this... do you guys know of any affordable av receivers with toslink input that are under 3.5 to 4" in height? or secondly, do you know of anything like the Creative DDTS-100 5.1 Decoder which utilizes a wireless remote but is not so expensive? I like the idea of the decoder because its small and I can tuck it away in a corner of the entertainment unit.
Thanks in advance
Thanks in advance
