AVS › AVS Forum › Video Components › Home Theater Computers › What is the best remote control application / solution ???? (for both Mediabrowser and XMBC ? )
What is the best remote control application / solution ???? (for both Mediabrowser and XMBC ? ) - Page 3
post #61 of 97
post #62 of 97
Originally Posted by Dark_Slayer View Post
If you are running a long cable, just run a long USB extension
Then tuck the IR -> USB dongle somewhere to keep it from being unsightly but in the remote's line of sight
FLIRC!!!!!!!
Linky ???
Not sure what you mean
http://lmgtfy.com/?q=FLIRC
That ?????
post #63 of 97
You need the RFX-250. The 150 was for the older MRF-300. The RFX-250i is for a different RF band. You need a basic RFX-250 (search eBay for examples). Your dad may still have it somewhere, have to just find the other end of that cable. The green connector next to it is also an RF input where you use the raw wires instead of the 3.5mm jack. It can all be connected with CAT cable as well. Otherwise you are good to go.
Notice the shiny smooth plastic front face? The MRF-350 can act as an IR blaster so you don't need any IR emitters for testing.
post #64 of 97
If they goal is to send keyboard commands from a remote to a pc, then run a long USB extension from your PC to wherever your remote happens to be
Then comes flirc (yes flirc.tv)
It's ridiculously easy to setup. Once configured it can be moved to any other computer as well and settings are stored. I set it up to send the WMC keyboard commands for most buttons, and since XBMC supports MCE remotes it acknowledges the same commands. I only had to add "m" and "c" to other buttons for XBMC
I also mapped Alt+F4, Shift+F10, tab, backspace, and Alt+Tab for conventional computer use along with Win+1, Win+2, Win+3, etc for pinned application launching from the taskbar
I use this remote since I already owned it for my PS3 http://cdn.shopify.com/s/files/1/0172/7870/products/blu-link9_medium.png?3269
I also picked up a basic learning universal for $5 at microcenter for my second flirc
My living room AVR and TV have HDMI-CEC. Samsung calls this Anynet, and the onkyo receiver just calls it HDMI-CEC. I set them up to stay powered together, i.e. when the TV power button is pressed it relays the same command to the receiver. I also had the option to let the TV volume buttons control the receiver volume. Then I used a cablebox code for the universal so it would allow almost every button to send an IR command. I changed the power and volume buttons by "learning" the appropriate commands from the TV manufacturer remote. Everything else got mapped in the Flirc config software to it's appropriate WMC keyboard shortcut
I like buttons. I've always thought the downside to expensive remotes was the "screen." Once WMC/MB or XBMC is set up properly, I don't need macros for "Watch a Video" "Watch TV" or "Listen to Music." It's pretty obvious from the menu options on the screen. I mostly need up, down, left, right, enter, back, and exit
The only thing that would truly ice the cake would be rechargability. Only the built-in screen remotes seem to come with a charger. The other thing that annoys me is the "TV" "Sat" "Cbl" "Aux" buttons. What was obvious to me at the age of 5 seems to have baffled older generation relatives of mine for years, and they really are a nuissance since we should really only need power/volume with an appropriately setup HTPC. If I had one remote that was rechargeable, had one power button (which it could learn), had learnable volume buttons, and looked nice I would be happy. Until then I just make sure to press the "Cbl" button at the top often. I'm very fortunate that the wife ALSO knows what to do when the buttons don't work smile.gif
post #65 of 97
So I would use FLIRC with the MX-900 ??? Right ?
I want one remote for all.
FLIRC is the best way to get my remote commands to the HTPC ??
http://asrock.com/mb/spec/Card.asp?Model=Smart%20Remote
How does it compare to that ???
( I have Asrock Mobo)
post #66 of 97
I don't know if it's the best, I'm sure there are plenty of good IR -> USB devices
I also have Asrock Mobos, but I'm not sure how well that IR receiver learns other remotes IR commands. Also the included remote doesn't appear to control anything but the HTPC. If it could learn volume commands or power commands for a tv or receiver it would be what you need.
I like the simplicity. It looks very similar to the Ceton Echo remote, which I also like. I'm extremely minimalist for remotes. I want every button to be useful and nothing that could be mistaken or duplicate should be present. This is all just my personal preference of course.
Flirc will work with any IR remote. It captures the remote's command and writes it to a keystroke stored within non-volatile memory.
There is a beta firmware that allows a flirc to wake your computer from sleep assuming you have a motherboard that supports wake from a usb keyboard
The remote you choose to pair with the flirc shouldn't really control much else since this would interfere with what you're doing. i.e. if pressing menu brings up a TV menu, it will still do this. For this reason, I just enter an incorrect device code into my universals, like a motorola cable box (which I don't have). That way the buttons don't do anything until I map them in the flirc config. Afterwards, all I need is the ability to control the TV/Receiver power/volume. My previous post describes this, but a "learning remote" should let you override a specific command. For example, I use a "Motorola Cablebox" template for the commands. Map all the buttons to something useful in flirc config. Then I want to override the "Power" button, because I would rather have "Power" turn my TV on and off. I take the manufacturer TV remote, point it at the learning universal, and press power so that the universal remote copies the TV remote's IR code for Power. From then on, "power" is the same command for either remote and either one will turn the TV on/off. Now I throw the tv remote in a drawer and just use the universal remote
post #67 of 97
So basically flirc can use and signal and you choose what each button does. ?
Versus the AsRock is going to you standard mapped WMC buttons
post #68 of 97
I have a Flirc guide for you to check out if you want to see it in action. It works very well.
post #69 of 97
You have too many guides... Lol
You use it ?
post #70 of 97
Sounds just like EventGhost. You let it receive any IR signal (1982 Sony Betamax Play button) and then make it trigger the MCE Play command.
If you want to have some real IR "fun" you should try Homeseer. I send my lighting commands from my remote via RF that gets converted it IR, runs through 35' of CAT cable, into a USB-UIRT connected to my server, that is received into Homeseer and triggers an event to send the proper Z-wave lighting command from the attached USB Z-wave controller. You can also use Homeseer with the USB-UIRT to transmit IR from IP signals sent from iRule.
post #71 of 97
Yes and no
The beauty of flirc is that you can pair it to ANY remote. Meaning a remote that can control your other stuff (TV, Receiver, lights, ??)
I've never used the Asrock remote. I looked at it's spec, and I couldn't find anything that indicated it could control anything other than your PC
If you go that way, you have to get a TV or Receiver remote and sit it next to you for Power and Volume commands. Then you grab the asrock remote for everything else. This is 1999 all over again.
If you go with something like I suggested you'll have 1 remote. If the asrock remote can learn the IR command to turn your TV on and off and adjust receiver volume then it could work just as well
post #72 of 97
I'm going to use the mx 900 I pictured
I just need fix and replace the RF receiver.
It can do any function so is use standard WMC remote mapping prob.
I already have multiple WMC remotes but no IR sensors.
I am looking for cheapest or best way get remote signals to HTPC.
Prob USB type thing. Flirc looks good option.
post #73 of 97
Step 1. Get universal remote that is RF and can control everything.
Step 2. Get signal from remote to HTPC with something.
I'm on step 2
post #74 of 97
Just get a MCE IR receiver. Not sure why you think you need flirc. You can program or learn the WMC codes into the MX-900 so no need to map alternates with flirc.
Just get the HP MCE IR receiver. It works well, has a transmitter, and is cheap.
post #75 of 97
I bought a couple those on ebay but each time it came with remote and not the dongle.
I got screwed because I did not look close.
Where is a good place to buy?
Link?
I grabbed the Rosewill version on newegg for $12 (gave to my brothers)
I hated the IR sensor. It had a headphone like jack and USB jack running to it. It was clunky and messy.
I guess the advantage of FLIRC is a can map a command to be a keyboard command for an advanced feature. Many players have shortcuts - those shortcuts could be buttons on the remote.
Seems easier with a FLIRC
but your right... 99% of my stuff is going to be standard so I might as well just go standard WMC remote style. (Cheaper too I guess)
Link anyone ? Where is good product / place to buy ?
post #76 of 97
The headphone like jack on the IR sensor is only needed if you are going to transmit IR. You connect an IR emitter to the jack.
Since you are going RF you will just slap an emitter onto the face of the IR sensor and can hide it behind/under something. Looks shouldn't matter.
Just find the cheapest USB IR receiver. It doesn't matter if it comes with a remote or not. Just don't get one of the Antec solutions... I just don't see the need for FLIRC when just starting out. You'll need the IR receiver anyway to use it so just see how things go without it at first.
If you have access to a Harmony you can program in the Window Media Center SE device and learn all these commands which are compatible with a standard MCE IR receiver
http://forums.logitech.com/t5/Harmony-Remotes-Programming/Expanded-control-for-Windows-Media-Center-now-available-in-our/td-p/374844
Win + - (plus or minus key) Zoom in or out.
Win-
Win+
Win+Up: Maximize
Win+Down: Restore / Minimize
Win+Left: Snap to left
Win+Right: Snap to right
Win+Home: Minimize / Restore all other windows
Win+T: Focus the first taskbar entry
Win+F: Open Windows search
Win+E: Open Windows Explorer
Win+Space: Peek at the desktop
Win+G: Bring gadgets to the top of the Z-order
Win+P: External display options (mirror, extend desktop, etc)
Win+M: Minimize all open windows
Win+1 / Win+2 / Win+3 etc (Hotkeys for programs added to the Quicklaunch)
Win+Tab: Flip 3D
Win+Shift+M: Undo all window minimization
Win+Home: Minimize all but the current window
Win + L: Lock the computer
Win + R: Open ‘Run’ command
Alt+1 / Alt+2 Alt+3 etc (Hotkeys for Video card display settings)
Alt+Esc: Cycle through all open windows
Alt+Tab: Switch to previous active window
Alt+Enter: Display properties for the selected item
Alt+Space: Pop up window menu
Alt+F4: Shutdown current window
Ctrl+A: Select all items in a document or window
Ctrl+C: Copy the selected item
Ctrl+X: Cut the selected item
Ctrl+V: Paste the selected item
Ctrl+Z: Undo an action
Ctrl+W Closes the tabs for most web browsers
Ctrl+Shift+Tab: Left Navigation through the web browser tabs
Ctrl+Tab: Right Navigation though the web browser tabs
Ctrl+ESC: Opens the Start menu
Shift+Del: Permently deletes an item and bypasses the recycle bin
Shift+F10: Opens Shortcut Menu
post #77 of 97
Link?
The rosewill controller I bought was just a usb dongle. I use it with my RF20 and I use Eventghost to map the buttons to anything I want. Keyboard commands seem more useful to me than mce commands.
An MCE remote would be easier in that you don't have to program anything though.
The Imon Ir receivers can be nice b/c some of them connect to your 24-pin motherboard connector so they can power on/off the machine. Not worth the extra money though.
post #78 of 97
Well... Like I said.
I have a harmony that can program via USB. I also have about 5 WMC remotes (a few HP, one Rosewill or generic etc... )
I also currently use an RF lenovo mini keyboard mouse remote.
My major problem has always been I never took the full time and effort to get myself to a complete solution. I just keep bouncing from one crappy solution to another. I have experience with almost all of them a little bit.
I need to bite the bullet and set up an RF professional solution for everything and just be done with it. I am fed up.
There is two issues I am working with:
#1. Setting up my HTPC to use remote commands via RF or IR (real remote not the lenovo)
#2 Getting a "real" universal remote that will do my whole system (through walls) and also turn off the lights etc...
I have an MX-900 URC model with the 350 base station. It's going to be my solution for now. I have the software to program it. It's a nice remote but lacks a few features I might want to upgrade later if this works out well.
My plan would be two fold.
First, I need to set up the MX-900 including HTPC controls.
Second, I need to get that signal to my HTPC. It would be nice to use the spare WMC remotes as such (SPARE) but not needed. The harmony is a nice remote too (not as good as the MX-900) but it won't work through a wall. It will be set up as an extra if I can't find the MX-900 in the seat or something.
So I guess I need to decide on what is the best way to get the remote signal to HTPC. Sounds like USB dongle is the way to go. A simple WMC based solution would work. Now I just need to find one.
Then I can send the IR signal (or RF) from the MX-900 system to that.
post #79 of 97
Sounds like a plan. Just need a USB IR receiver and a RFX-250.
post #80 of 97
My friend is getting me a price on the RFX-250.
I've been scanning ebay too.
I still need to find a good USB IR for my HTPC. Suggestions appreciated.
post #81 of 97
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181040451537
I actually have one of these I found in my basement. lol.
I was wondering where it went. I thought I gave it away.
I'll try it out for now.
post #82 of 97
For someone like you a gc-100 could be very interesting. I plan on picking up something similar eventually.
post #83 of 97
what is a GC-100
post #84 of 97
what is a GC-100
http://lmgtfy.com/?q=GC-100
post #85 of 97
post #86 of 97
First result, BTW.
post #87 of 97
I freakin love doing that so much I did it to myself. lol.
post #88 of 97
The GC-100 is IP to IR. Sort of backwards when not using a WiFi remote.
post #89 of 97
I didn't mean it as a suggestion for his current project.
post #90 of 97
Right.
I'm going to use MX 900 fit now.
I'll prob upgrade the remote in future and still make use if the other stuff I have like base station.
