AVS › AVS Forum › Video Components › Home Theater Computers › What is the best remote control application / solution ???? (for both Mediabrowser and XMBC ? )
What is the best remote control application / solution ???? (for both Mediabrowser and XMBC ? ) - Page 4
post #91 of 97
any advice for using the remote CCP software ???
lol....
This looks like it's going to take a while...
post #92 of 97
lol....
Click Help on the menu, then the Tech Guides button.
Open "MX-900 KP-900 CCP programming manual.pdf".
Profit.
There is also a "Programming in CCP.pdf" file for general programming.
Look, two guides and you don't even have to pay to view them.
post #93 of 97
post #94 of 97
post #95 of 97
Pretty good grab. If it doesn't work out for you I'm sure you could sell it for a small profit.
Make sure your MRF-350 isn't set to zero (on the bottom of the unit). Zero is the testing mode where the red light will show how much RF interference it is receiving. Set it to any other number and remember that number for when programming it into CCP. That number is also how you can run more than one MRF-350 in the same area. When adding the MRF-350 to CCP it will ask for its RF# and that is the number you set. Then for each device you set to RF control and chose which of the six IR ports to use (or select ALL).
post #96 of 97
Is it possible to get the software if you buy an mx900 off of ebay or is this only possible for you because of your friends?
post #97 of 97
