Well I'm finally re-building new subs. The compact "sealed with boost" setup I have now works very well, but I figure I should go bigger bass reflex just because I can. I jumped on CSS's APR15 sale last year ($60 ea shipped!), and got 4 of them. These are very simple to use with the included 900g washer kit and outer attachment point, one could adjust their tuning on the fly at any time.
http://www.creativesound.ca/details.php?model=APR15
I'm reusing my MOFO 152X woofers, and O Audio 500 watt amps
http://www.poweracoustik.com/pa2012/subs-MOFO-152X.html
My intended design is 6.5 ft3, with the dual PR's loaded with the full 900g mass for a 17hz tune. I'm going to down fire the active driver so I dont have to look at it (I considered repainting the blue areas), with the PR's side firing.
My actual box is probably going to be about 0.2 ft3 smaller, which shouldn't be an issue when those dimensions give 7 ft3.
WinISD model of the native alignment
And with the Oaudio's 20hz filter boost added
I'm predicting a rise below 30hz wont be a big deal due to sound perception, but I'm placing the amps out of the enclosures this time just in case I decide to change my amp setup.
The side panels are only going to be 1/2" ply, so I'm adding stiffeners
