I'd like to have content from online and also my computer going to my LG PA70G. I tried coming out of the VGA computer port into the VGA port on the projector and was not pleased with the results. Image quality was lacking. Is there a better way to connect these units, or do I need to change resolution setting on the computer? Image was letter boxed more than screen on laptop, not very bright, and not sharp at all. The projector is ceiling mounted and would take 30' of cable for whatever connection I use so that cables will be hidden in walls and attic. Thinking of getting a Roku also. The size of the Roku is such that I could mount it up with the projector and use a very short HDMI cable and only need to run audio cable for the 30'. How have all of you found as the best way to input the signal? Can I attach a usb cable directly from a computer to the usb input on the projector and play content from the computer and online sources? Will that give a better result than the VGA input? Have had projectors for 20 plus years, but all were CRT's. Loving the size and performance of the PA70G; just want to get the best use of it possible. Not excited about a 30' HDMI cable though.
AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Online content to LG PA70G
AVS Top Picks
