A buddy gave me his old broken 360 to try to fix and use. It did display video and sound at first albeit pretty lousy until it went out completely. I tried the right trigger +y idea to no avail as well as three different sets of av cords - two of them are known good cables. It boots up normally and does not display any errors or red lights. I've read a lot of different solutions, some that conflict with one another's advice as most of the posts were pretty old. I'm more than willing to replace the x clamps with screws, nylon washers and new paste if that's the solution. I'm not to crazy about overheating it or throwing it in the oven but I will do it if you guys still think these are still viable options today.
The board wrapped in foil with the underside fully exposed, the top only had the gpu, cpu and memory chips exposed. 8 bolts, some metal and nylon washers and its a success. This was a fun project. I wouldn't mind fixing a whole bunch of these!
