Hello Everyone. I have seen tons of great advice and have spent a day reading alot of the other posts but as always I would love to have some personal advice. I want to cut my dependency on Time Warner Cable for Television service and am starting with a clean slate. I would like to use the mounting bracket on my garage that a previous Direct TV Dish was mounted on to install a small Mast and Multi-Directional Antenna. I only have 2 Televisions in the house but it is a bigger house with a long run from this mounting location to the area where the single Coax Cable Feed is split inside the basement. I would like to use existing wiring inside house if possible and the house is situated in a north to South direction with the garage on the north side of the house and the second floor of the brick colonial blocking maybe 10-15 degress of the south. I also have large trees around me and a bit of a hill to the west that elevates about 20-30 feet above the top most point of my house.
Hope that description makes sense.
Any recommendations or ideas for how I should approach or take on this project?
Here is my TV Fool Link
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda88491f5eaf
Thank you so much for your time and any guidance.
Jeff
Jeff
