I had planned pretty standard treatments for my dediacted room up to a couple of weeks ago:
2 inches of 703 equivalent on front wall
1 inch of linacoustics equivalent on side walls up to just over ear height
First reflection points treated
2-4 inches on rear wall up to ear height (Denis Erskine general advice I think but am open to correction) or to full height on rear wall (Bryan Pape general advice I think...)
Corner triangle bass traps
No definite plan for soffit treatments as advice for soffit bass traps is conflicting.
Then I was going to do an REW test - then add or take away acoustic treatments as needed. Fairly standard stuff.
All was well until about a week or two ago when it was suggested to me that acoustic treatments in the standard manner ie like the above plan make rooms that are too dead, lifeless and "unpleasant to sit in", and the best approach is to design a room with a normal reverb time and only if necessary, then add some side wall diffusion."
I don't have any strong opinion on this as I'm just at the point where I need to decide on acoustic treatments so I dont have any prior experience, and I know the vast majority on here use very similar treatments but I'd be interested in opinions on this alternative view.
