AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › Amazon ordering help
post #1 of 2
So I want to buy the Epson 8350 on amazon for $1150.00 I think.
I want to be able to use my Amazon Store Card. I have a limit of $599.
I want to be able to put $599 on my card and the rest on Amazon gift cards.
How do I do this easily?
Sent from my SCH-I605 using Tapatalk 2
post #2 of 2
My, you are an antsy fellow smile.gif and this is surely not the forum for this question. Anyway what I would do is add the projector to your cart. If you have a default payment option, select change. There's a field for gift cards and you should add those one by one. After you apply those, you would select the Amazon store card.
