Hey guys, I have columns on my front wall which will contain my towers. So I'm paneling those columns with FR701 black as well as the rest of the front wall. Problem is when I hold up my sample I can see straight through the column to the OC703 on the wall pretty easily. Doesn't seem to be an issue when the fabric is directly on the 703 but when it's set back like in the columns, I'm a little worried. Should I order enough to put fabric directly on the 703 or just get some speaker cloth from joannes or something to lay over the insulation?
AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › FR701 Black
FR701 Black
AVS Top Picks
post #2 of 13
2/5/13 at 7:11am
post #5 of 13
2/5/13 at 9:40am
post #7 of 13
2/5/13 at 2:27pm
post #8 of 13
2/5/13 at 3:06pm
post #9 of 13
4/3/13 at 1:13pm
post #11 of 13
4/24/13 at 6:24pm
post #12 of 13
4/24/13 at 6:31pm
post #13 of 13
4/25/13 at 9:37am
AVS Top Picks
