AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Advice on in-wall speaker enclosure
post #1 of 6
For my HT project, I have added 4 angular areas that will house speakers in the walls. The area is wired, but I am a little lost how to construct removable enclosures. Anybody online makes these that I can order ?. Or do I need a carpenter ?. I will have 4, 2 each in the front and rear.
Please advice .
post #2 of 6
size and shape of enclosures?
post #3 of 6
Price?
Pretty much the sky is the limit as far as how expensive speakers can get.
post #4 of 6
Thanks for your response. I am looking at buying in-wall speakers instead of trying to use my current speakers with cabinets.
The speakers I have shortlisted are JBL SP811 for F/R and Surround. The SW is ES250P. Looking for a center speaker that I can use.
Any advice ?.
post #5 of 6
first you ask about enclosures, now you ask about a center speaker, next you'll want a good recipe for bread pudding.
post #6 of 6
LOL !. Sorry, I know I am all over the place.....will repost after I get my thoughts together. The bread pudding does look yummy.....
