AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Av receiver with HDMI in and optical out
post #1 of 7
Hi guys, I am trying set up my games room and need some help deciding on the best way to do it. I currently have a computer, xbox360 and PS3 connected to my 27" monitor through a 3 port HDMI switch which is great for video but not for audio. There is a 3.5mm audio jack on my monitor which I connect to my 2.1 speakers for sound which is good for now but... I have just purchased 5.1 wireless headphones that have optical in so I am thinking of getting an av receiver to control all my devices so I can get video through my monitor and sound through my headphones. My headphones also have optical pass through so I can still use my speakers and will only need 1 optical output. Any ideas on how I could achieve this would be greatly appreciated.
post #2 of 7
No such AV receiver exists. You can get an HDMI switch with an optical out instead. Note that the audio format has to be in a SPDIF compatible format, they don't do format conversions. This isn't a problem with your Xbox 360 since it only supports SPDIF compatible audio formats, but you'll have to configure your PlayStation 3 not to use multichannel PCM, DTS-HD and other high bandwith formats. Your computer may be limited to just stereo.
post #3 of 7
Ok cool now from reading a few thing it seams that if your output HDMI device is not 5.1 a switch with toslink out wont be able to transmit 5.1 signal. Just wondering if this is the case? Also after searching for a HDMI switch as described I have found this one Pro 2 HDMI4AVR http://www.avaustralia.com.au/products/Pro-2-HDMI4AVR-4-Way-HDMI-Switch-With-ARC-%252b3D.html
If anyone has used one of these any input would be good.
post #4 of 7
post #5 of 7
Well, I suppose there's some chance I'm wrong and there exists an AV receiver i've never heard of capable of converting HDMI audio in to optical audio out. However such a receiver would need to have at least one HDMI input, something that neither of the two models you linked to are equipped with.
post #6 of 7
It used to be common in Denon receivers. You can grab a used Denon 3808 on ebay for about $300 or so.
post #7 of 7
The 3808CI cannot convert HDMI audio to optical, rather you're likely thinking of the fact that the 3808CI (and some older models) can convert optical/digital coax PCM 2.0 to analog for Zone 2 output. The only way to get optical output on the 3808CI is to have optical/digital coax input as well.
Edited by jdsmoothie - 4/18/13 at 2:29am
