AVS › AVS Forum › Display Devices › Screens › Looking for screen
Looking for screen
post #1 of 5
Screen Size: 130
Throw: 11-13 (Could be further if off center is alright by about 1-2 feet)
Sitting distance: Under the projector so about 10-11 feet from the screen.
Lighting: Some ambient lighting from computer screens(not directly at the screen but in the same room), white walls
Uses: For movies, tv, and gaming
Time: Both day and night but I should be able to make it pretty dark in the room.
I am planning to buy the BenQ w7000.
I was looking at the Elite Screens on amazon and they seem pretty reasonable but I don't understand the whole 'cinewhite" or "gain" stuff. What should I be looking for? Are those screens good for their price? This isn't a permanent residence either so are those screens hard to take down? Should I opt for something a bit more expensive so that I could possibly move it in a few years or just go with this and when the time comes to move deal with the hassle?
post #2 of 5
Ok looking around at screens, whats the difference between these screens, except one is about 200 less...
First one I was looking at (the 130 option):
http://www.amazon.com/Elite-Screens-ER106WH1-Projection-Screen/dp/B00366KE42/ref=cm_cr_pr_product_top
Second one (the 125 option):
http://www.amazon.com/Elite-Screens-ELECTRIC125H-Projection-125-Inch/dp/B000Q87LM6/ref=pd_sim_e_52
The second one is cheaper and can go up and down electrically....
And this one (in the 120 16:9 white)
http://www.amazon.com/Elite-Screens-M100XWH-Manual-Projection/dp/B000B60LVG/ref=zg_bs_392442011_11
That's even cheaper and can go up and down manually.
Is the option to make it go up and down a bad thing?
Edited by SubSt8 - 2/5/13 at 6:37pm
post #3 of 5
1. 1.1 ciniwhite 16:9 screen 106 inches in a 2.36 inch frame.
2. 1.1 gain MaxWhite 16:9 electric drop down screen 125 inches (a bit larger)
3. 1.1 gain MaxWhite 16:9 drop down screen 100 inches.
Both are white 1.1 gain screens.
Do you need to your screen to roll up?
http://www.elitescreenshop.com/product-p/sm-maxwhite.htm
http://www.elitescreenshop.com/product-p/sm-cinewhite.htm
Read about the materials and decide for yourself. Elite says the cinewhite is better.
Have Fun!
post #4 of 5
Originally Posted by SubSt8 View Post
Screen Size: 130
You had better plan on about 15-1/2' for throw if you want to fill that size screen. Also plan on dim 3D if using 1.1 gain screen and that is in a good light controlled room. With white walls and white ceiling, not sure 3D is much of an option at that size, using that gain. It will work for a little while, with a new lamp.
post #5 of 5
I'll second you doing a bit more research. If you don't have a basic understanding of screen ratios, gain, etc then you may want to seek professional advice before you spend money on a screen that won't work for you. I purchased from Mike at was very pleased with the service. I would suggest giving him a call at the very least.
  Back to Forum: Screens
