post #1 of 1
I'm looking for a RF remote control to use with my HTPC. It also needs to be able to power on my TV and adjust the volume. I have been using Nyxboard, i love the design but i HATE it because it is full of bugs. It never gets detected by the computer. Dozens of other users have the same problem (just look at Pulse-Eight forum) and the manufactured isn't doing nothing to fix it. I need a more reliable alternative.
- Power on/off TV through IR learning
- IR volume control for TV
Needs the following RF buttons:
play/stop/volume/back/info of course with arrows and "ok" button"
Those buttons should be RF since i will control my HTPC from a different room.
It would be awesome if the remote had programmable RF buttons so i could also control my lights with my insteon system, but i know it's too much to ask so let's say this is optional
1) I DON'T WANT A KEYBOARD, i want a REMOTE
2) Harmonys are too expensive.
Remote will be used for XBMC
Thanks !
