AVS › AVS Forum › Audio › Receivers, Amps, and Processors › audio on hdmi
audio on hdmi
post #1 of 6
Hi...
If i connect my streamer to my reciever through hdmi is it enough to get the maximum out of the audio or do i need to connect a fiber optic audio cable in order to maximize the siund expirience? (Sorry for the ignorance)
post #2 of 6
HDMI is what you should be using.
post #3 of 6
One cable of hdmi is used for display + sound (including dts and 5.1 speakers sound system)?
post #4 of 6
Yes. And 7.1 lossless if everything you have in place supports it, too.
post #5 of 6
Wow great... no more digital rca/fiber optic cables for audio...
Do i have to check anything on my source or it is enough that it has hdmi output that it will work?
post #6 of 6
You still need to configure your player and receiver for optimal audio performance and select the best source when more than one is available.
