AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "OFFICIAL" Pioneer SC-1222-K Owners Thread
"OFFICIAL" Pioneer SC-1222-K Owners Thread - Page 40
post #1171 of 1383
Thanks for the replies guys. I've read through all 39 pages of this thread
so I was aware of the shortcomings of the 1222 compared to the 1522
and some of the workarounds.
From what I could find out, looks like most of the 1522's hit Costco
last March and now the 1222's are showing up. Since I was coming
from a Denon 2808CI that was stolen, I'm sure this will do all I need
for now and more.
At the price I got the 1222 ($514.17 with tax here in WA state)
I won't mind upgrading if I need to down the road.
My old speakers consisted of Klipcsh that they stopped making
in 1997. I kept them in immaculate condition and would still use
them except when the idiots broke into my storage unit, the only
speaker they stole was one of my towers. So I have one tower
left that does me no good. Still have the old 2.5's for surround
and a KV-12 sub that I loved along with a fairly small center,
can't recall the model #.
I have the funds to upgrade the speaker system and that's
why I was picking the Axioms. I believe the 1222 should
work good with them.
Thanks again for all the help and information. For people like
me that have been out of the loop a long time, forums like
this make all the difference.
Have a great weekend!
Greg
post #1172 of 1383
Hi I read through the whole 40 page thread. Great info. I recently picked up the 1222K from costco. I have connected Polk CSi5 center with Rti6 Fronts and energy take sides and 8" Energy take sub for a 5.1 setup. I will probably change it to a 7.1, I have the two energy take sats sitting around doing nothing. I have a few questions if someone can please give some insight.
1. When doing the MCACC with THX, my sub still sounds dead. If I bump it from from -2.0 db to +3.0db I finally feel it. I noticed the MCACC is putting my sub distance at 23 ft when it is close to 13 ft (around the same as the fronts). Is this something I should change manually? Also why is it so off? I have to go through the guide for the sub. Have the pdf downloaded. Lets see if that makes a difference in the overall quality.
2. Lastly I also used have a Onkyo SR606 and Denon AVR1613. When getting a stereo signal they had the option to output to all speakers. I have my HTPC and HD cable box connected to the Pioneer. On both when there is a stereo signal, it outputs a 2.1 signal only. I messed around with all options but couldn't figure out how to output stereo sound as 5.1 (basically audio to all speakers). Can someone please advice me on how to do this. Thanks.
post #1173 of 1383
the option is called extended stereo.
post #1174 of 1383
acoustic distance vs physical distance. acoustic distance takes into account lag going thru DSP processing and mostly likely phase. and most will tell you to not change it to physical distance.
this all assumes you had the mic positioned correctly @ the main listening position, on a tripod or at least the seat back, nothing blocking the line of sight to each speakers and aimed at the ceiling (not tilted forward or back). IF your seat is right against the rear wall, this also may have an impact on how it measures things.
post #1175 of 1383
Thanks. Anyway to make this default for 2.1 signals?
Yeah nothing is really blocking the sub, I have mic on a tripod sitting on top a box and leveled so it pointing straight up. I'll try again after I switch to 7.1 setup.
post #1176 of 1383
The processing mode is remembered per input but there is no way to do so per signal types. I typically only use it for certain inputs that are stereo all the times, e.g. FM radio or Media Server/internet radio/Pandora etc. My cable TV inputs are mostly 5.1 (don't watch low res SD channels at all) but it will be really weird if I change channel from a 5.1 HD channel to a 2.0 SD channel and all of sudden the speakers switched to extended stereo mode. That mode is only good for party IMO and put heave load on receiver as well.
post #1177 of 1383
Hi,
Can anyone tell me what are the differences between the SC-1222 and SC-1223 except the second HDMI output? I would like also some recommendation regarding a 5.1 speakers (brand, model) should I buy it a a package or just go for individual components.(600-1000 USD)
George
post #1178 of 1383
SC-1222: 2012 model. Can be found in Costco for much less than MSRP
SC-1223: 2013 model. There is no discount so far.
post #1179 of 1383
The 1223 loses a most of the pre-amp terminals compared to the 1222 and looks to be a step down. You'd have to go to the 1323 to get a similar setup.
post #1180 of 1383
Hey guys,
New to the thread. I did post a "problem" I have with the SC-1222-k and a Samsung TV on the other thread.
I am looking for suggestions.
Here:
http://www.avsforum.com/t/1441190/pioneer-sc-1222-k-anyone/360#post_23822679
Let me know. Thank you in advance
Nick
post #1181 of 1383
HDMI CEC is really quirky no matter what vendor. With my LG tv when the 1222 syncs up and powers on and off with it and the direct tv box it switches to the TV input even if the CBl/Sat Was previously selected. I tried using both the ARC and regular input with no change.
I deal with the quirkiness because its the easy way to control receiver volume with DirectTv remote.
post #1182 of 1383
based on hundreds (maybe thousands) of posts over years about various gear issues when HDMI CEC (HDMI Control) is used, you have a good observation, sir wink.gif even I with Pioneer AVR's and Pioneer Kuro plasma, leave it Off; for me, it's not worth the bother. the only time I have it On is when I want to listen to music with Pioneer's PQLS.
I can't use the ARC (audio return channel) feature with my kuro but even if I could, it also seems even more quirky, if that's possible. again, a feature I personally have no use for. I connect audio from my cable box directly to the receiver, so that negates the need for ARC - an optical connection is simple and it works 100% of the time wink.gif
post #1183 of 1383
Well, thanks guys for removing my last hopes ;-) .
It would have been cool though...
When the SC-1222-k goes from STEREO" back to "TV" then back to "STEREO" is what screws it up I think.
I'll still experiment more with it later.
On the other hand ARC has been working well with OTA sources (on the TV side). I still have to see with the network / Internet though.
Nick
post #1184 of 1383
Successful Firmware Update!
Just wanted to post a follow up about the firmware update on the SC-1222-K.
From all the instructions I could find, it was obvious that you had to have the
updated firmware files on the ROOT drive of your USB thumb drive.
What I couldn't find out and figured out through trial and error, is exactly which
files needed to be on the thumb drive. From a picture I had seen in an earlier
post, you could see the name of the file that the receiver recognized and that
coincided exactly with the FOLDER NAME after unzipping the original file.
So I 'assumed' that meant that the FOLDER is what needed to be on the
thumb drive. So I downloaded the ZIP file and extracted it several times on
the thumb drive so that folder was showing.
Of course that didn't work. I tried several times, each time reformatting my
thumb drive to FAT32 with the same results. So I figured it was the brand
or some other problem with my thumb drive. So I headed out to Best Buy
and picked up another cheapy thumb drive and the result was the same.
Error message after ACCESSING the file.
Finally I decided to download the ZIP file to my desktop, then extract the
7 individual .BIN files ONLY to the thumb drive. Plugged it into the front
of the receiver, hit update and BINGO, it worked! The update ran and
worked perfectly. The receiver shuts off after reaching 100%, turned it
back on and checked the software version and everything was golden.
Just a suggestion... maybe add specific instructions on the first post
in this thread to help anyone new that purchases a 1222K. Sifting
through 40 pages of content can be a daunting task and no where,
even on the Pioneer site, did I find anything saying to ONLY load
the .BIN files, nothing else. Maybe it's obvious for some, but I think
for many, it will be confusing without being more specific.
Also, the links for the wireless adapters in the first post are both
out of date. Seems many 1222K owners are using this Netgear
unit with good success:
http://www.netgear.com/landing/wnce2001.aspx
I'll be picking one of these up today from my local Staples.
And also maybe add the bass tweaks PDF file from user bad1550
from page 21 to the first post as well:
https://www.dropbox.com/s/wcvouknssbseg0m/MCACC_SUB_EQ_1_3.pdf
Please don't think I am being negative about this thread. I'm only
offering input from my own experience. This thread has been a
world of help to me and I'm sure many other 1222K owners. I'm
only saying that maybe updating the original first post might be
helpful to new 1222K owners in the future.
Thanks to everyone who have contributed to this thread, I really
appreciate it!
Greg
post #1185 of 1383
From Pioneer's SC-1222 page, the update instructions (SC-1222-K Firmware Update Instructions):
Unzip the ZIP file and save all the unzipped files on the USB memory device.
I guess that could more specifically say "and save the INDIVIDUAL unzipped files...."
Glad you figured it out.
And glad it worked!
I'm personally not a fan of the "bass tweaks" posted. MCACC, as he illustrates, only calibrates to 63Hz. Boosting that and the frequencies above it will only serve to overwhelm any deeper base your subs can produce, adversely affecting the overall sound:
http://www.independentrecording.net/irn/resources/freqchart/main_display.htm
You're better off just adding a few dB to the sub output setting (Fine Channel Level) after MCACC. Search for "house curve" for the rationale for that.
That said, you're MUCH better off using measurement software and doing it right, as per the thread here: http://www.avsforum.com/t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs
and especially the guide, here:
Link to REW 101 v3.0.pdf
One of the very nice things about the MCACC system is that it allows modifications after the calibration. But those modifications should be done sparingly, and very carefully.
Michael
post #1186 of 1383
That's great advice Michael and I really appreciate
all the links to the info as well. I will dive in and check
it all out.
I know I still have a long way to go to understand the
proper way to set up my system, but I love learning
this stuff!
Thanks again!
Greg
P. S. Here's a pic of the current set up:
post #1187 of 1383
post #1188 of 1383
Hi - How do I get zone 2 audio for my hdmi outputs? I am able to select it but no audio comes out. The only thing I can get for zone 2audio to play on speakers is Tuner and airplay. I would like to send what I'm watching throughout the house via zone 2.
post #1189 of 1383
Hi jdpublic, you can't send HDMI source to Zone 2. Only analog signals like the tuner or an attached analog source via the RCA (red & white) connectors.
post #1190 of 1383
The rca zone 2 audio outputs are only driven by other rca/analog inputs (plus the tuner & network sources - although zone 1 can't use a different network source) The zone 2 video output is driven my the rca video inputs. So there are 5 RCA a/v inputs on the 1222k, so for some HMDI sources, you can run the RCA cable as well (the zone 2 selectable sources are the ones with rca inputs) . For example, I run both hmdi and rca from my DVD player to the receiver. HMDI plays in Main, dvd->rca plays audio and video in zone2.
post #1191 of 1383
Now it all makes sense. I got it to work as you described. Thaknks for the help.
post #1192 of 1383
Is this the problem I have when listening to music and no base is run through my sub and only through my fronts? I notice it when I am listening to any of the audio channels on dish network along with when I have my iphone plugged in and listening to music. Would the extended stereo function cure this?
post #1193 of 1383
No, the problem is you need to set all your speakers to SMALL, then the subwoofer will handle all of the lower frequencies.
post #1194 of 1383
I understand but the display on my receiver shows only the fronts when it recognizes something in stereo. It doesn't even show the subwoofer on the display like it does when watching something in 5.1 or 7.1
post #1195 of 1383
Stereo is 2.0. You can use the Extended Stereo option and it will us all speakers.
post #1196 of 1383
All speakers including the sub? While we are talking about it... What settings does everyone use just to listen to music? Does it really matter what kind of music it is? I listen to everything from rap and hip hop to classic country. These are some of the things I haven't tinkered with on my receiver yet. Thanks
post #1197 of 1383
There are several "sound fields" that are more gimmick than useful compared to previous Pioneer AVR's I have had. But when listening to music I use the Ext. Stereo (Extended Stereo), which unlike my D909S which used all the speakers equally, this doesn't as far as I have seen/heard. As time goes on I become less impressed with this unit and Pioneer. And from what I gathered from Pioneer TS, this unit is EOL (End of Life) and the severely limited support that we were getting, is now gone. So no more FW updates. Not that there were many to cover issues in the first place. /rant
I would suggest just putting on your favorite cut and scrolling through the options to see what they do for you and to the music. It's all subjective.
Edited by FarmerBob - 10/21/13 at 2:55pm
post #1198 of 1383
+1
absolutely. there is no right or wrong format. just one that sounds pleasing or what your preference is for one's room, speakers and setup.
that said wink.gif personally, I do think most of the so-called Advanced Surround modes are not useful, actually can degrade the sound quality, because they add artificial reverb in varying amounts to the sound. as I very recently posted in another Pioneer thread, the only company that actually used acoustical modeling of concert halls, jazz clubs, etc for their "presence" reverb modes was Yamaha. all the rest are totally artificial. but they are there if one wants to experiment with them smile.gif
Edited by ss9001 - 10/21/13 at 2:54pm
post #1199 of 1383
Hi all,i have the 1223k as replacement of my 1222k, now this is the problem.Yesterday i start a movie on my old fat ps3 and my PCM signal is gone,if i set up the ps3 to linear pcm in the ps3 i have no dialog on the movie but got sound effects and the pcm display on the receiver screen too..Now if i set up the ps3 to bitstream i have dialog and sounds but no pcm display on the 1223k .Maybe i have to recalibrate the receiver?I play back and forward with the settings on the ps3 linear and bitstream but same results.I have a second slim ps3 and i try that one too but same issue maybe i have a wrong setting on the receiver somehow.Hope you understand english no my first language.Thanks.
post #1200 of 1383
Sounds like you set up ps3 output via s/pdif or dual instead of hdmi output set it just to hdmi
