Originally Posted by okibcn
Just to mention that the page doesn't show when using Google Chrome Internet browser. Microsoft Internet Explorer seems to display it properly.
For people trying to find the differences between the cheapest class D3 amplifier (Pioneer SC-1222K) and the second cheapest D3 amplifier to date (Pioneer Elite SC-61):
- SC-61 has 2 12V triggers for remote systems, SC-1222K doesn't have any.
- SC-61 has 2 IR inputs while SC-1222 has just 1.
- +1 Year Warranty for the SC-61
- Display color in amber for the SC-61, blue for the SC-1222K
- ELITE logo in the front keypad door in the SC-61.
- SC-1222K can be found down to $550, and SC-61 down to $716 while Pioneer's MSRP is $1100 for both to date.
The rest is exactly the same, including the remarkable amplification stage. There was some confusion in other threads about a couple of features that both the SC-61 and SC-1222K actually share:
- Both have Hi-Bit 24bits up to 48KHz Audio (requantization enhancement system for lower bit depth audio sources).
- Both have Manual MCACC.
Regards
Regards
Thanks again for the awesome info above. So I was just browsing amazon reviews on the SC-61 and found this...
MCACC vs Audissey
I prefer MCACC. Audissey MIGHT be better if you have a subwoofer (MCACC will not touch your sub at all, you need an external tool for that), but, first, I hate subwoofers and don't have one in my setup, second, the Audissey calibration is too flat and boring. MCACC does a much better job, with a more lively sound, and it SHOWS what it does after it's done calibrating your system. You can review the calibration data and see decibel changes to each speaker, charts, and EQ parameters. You don't get that with Audissey.
To clarify, do all Pioneer receivers have this issue where the MCACC won't touch the sub? Another poster said the following...
"Yes, the sub out cannot be EQd by the MCACC feature (this is apparently the case even with the top Elite versions), but one can purchase an outboard mono equalizer (like, say, the ART EQ351) and use it to EQ the subwoofer feed. MCACC is actually a very useful feature with the Pioneer line."
What is this exactly?
