It couldn't be the receiver. Now you can enjoy the full potential of your system.
Congrats!!!
Originally Posted by korkster
I'm wondering the same thing. With my old Kenwood, I barely had the volume a quarter turn. Now I have it cranked almost to max. I'm also hoping I'm plugged into the right output. The quick start guide shows subwoofer 1 but the av navigator showed it going into the zone 2 out which didn't make sense to me.
I recommend not using the AVnavigator. the PC version has some bugs, like that known bug in the sub connection. Use directly the manual. it is really good.
I finally had a chance to set mine up today. It was delivered on Tuesday, but I was away on business. I've got a lot of tweaking to do, but have things working for the most part. I have a couple of concerns at this point in addition to the low subwoofer output.
I'm having issues with the remote. It controls the volume, and will change inputs, etc., but it won't open up the home menu nor control anything in the menus. I've had to do it all at the receiver. Is it a bad remote or is there some setting that needs to be addressed to give it full control?
Another issue is getting audio from tv to the receiver via optical cable. I'm sending audio, as well as video, directly from the cable TV box for watching TV, but I had been taking advantage of the smart tv features by sending audio back to my receiver via digital optical, and it worked fine with my Kenwood. I've got no sound with this, and I checked to make sure I reconfigured the input settings. Is there something I'm missing?
I'm a bit frustrated at this point. I didn't have HDMI capability with my old receiver, but I'm wondering if maybe simpler is better. Hopefully I'm just making some rookie mistakes with the set up so far.
I do not have any problem with my bass, you must be missing something. Have you already calibrated the system with the Adv. MCACC?
I recommend connecting the TV only through HDMI and connect everything else to the receiver. nonetheless it will work if you connect both to the TV, Forget the optical link for audio. That was the past.
Regards
